Rohde & Schwarz EPL1000
Jump to: navigation, search
Front view of a Rohde & Schwarz EPL1000
Back view of a Rohde & Schwarz EPL1000
The Rohde & Schwarz EPL1000 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz EPL1000:
The frequency range of the Rohde & Schwarz EPL1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz EPL1000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz EPL1000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
