Rohde & Schwarz ESCI (10 dB Attenuator)
The Rohde & Schwarz ESCI (10 dB Attenuator) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESCI (10 dB Attenuator):
The frequency range of the Rohde & Schwarz ESCI (10 dB Attenuator) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESCI (10 dB Attenuator).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESCI (10 dB Attenuator) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz ESCI (10 dB Attenuator)
- Google image search: Rohde & Schwarz ESCI (10 dB Attenuator)
