Rohde & Schwarz ESH2 Z11
The Rohde & Schwarz ESH2 Z11 device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESH2 Z11:
The frequency range of the Rohde & Schwarz ESH2 Z11 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESH2 Z11.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESH2 Z11 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz ESH2 Z11
- Google image search: Rohde & Schwarz ESH2 Z11
