Rohde & Schwarz ESMI Input 1 (NLR Input 1)
The Rohde & Schwarz ESMI Input 1 (NLR Input 1) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESMI Input 1 (NLR Input 1):
The frequency range of the Rohde & Schwarz ESMI Input 1 (NLR Input 1) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESMI Input 1 (NLR Input 1).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESMI Input 1 (NLR Input 1) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz ESMI Input 1 (NLR Input 1)
- Google image search: Rohde & Schwarz ESMI Input 1 (NLR Input 1)
