Rohde & Schwarz ESPC (Receiver)
Jump to: navigation, search
The Rohde & Schwarz ESPC (Receiver) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESPC (Receiver):
The frequency range of the Rohde & Schwarz ESPC (Receiver) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESPC (Receiver).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESPC (Receiver) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
