Rohde & Schwarz ESPI 7 (10 dB Attenuator)
Jump to: navigation, search
The Rohde & Schwarz ESPI 7 (10 dB Attenuator) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESPI 7 (10 dB Attenuator):
The frequency range of the Rohde & Schwarz ESPI 7 (10 dB Attenuator) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESPI 7 (10 dB Attenuator).
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESPI 7 (10 dB Attenuator) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
