Rohde & Schwarz ESR 26 Input 2 Scanning Receiver
Jump to: navigation, search
The Rohde & Schwarz ESR 26 Input 2 Scanning Receiver device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESR 26 Input 2 Scanning Receiver:
The frequency range of the Rohde & Schwarz ESR 26 Input 2 Scanning Receiver as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESR 26 Input 2 Scanning Receiver.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESR 26 Input 2 Scanning Receiver is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
