Rohde & Schwarz ESU Controlled LISN
The Rohde & Schwarz ESU Controlled LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESU Controlled LISN:
The frequency range of the Rohde & Schwarz ESU Controlled LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESU Controlled LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESU Controlled LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
The Rohde & Schwarz ESU Controlled LISN device driver can be used to automatically control LISNs that are connected a R&S ESU-series analyzer.
Instead of controlling the LISN itself, RadiMation® will connect to the R&S analyzer. The R&S analyzer is connected to the LISN, by using a cable between the userport of the R&S analyzer and the LISN itself. The definition of the cable, and how it should be connected is very often described in the manual of the LISN itsef. When another line of the LISN should be selected, RadiMation® will send the correct command to the R&S Analyzer, which will activate the correct outputs on the userport of the R&S Analyzer.
This device driver is no only working for the R&S ESU, but also for all the other related Rohde & Schwarz analyzers from the same series. Thus also the LISN that is connected to a Rohde & Schwarz ESW can be controlled by using this device driver.
Example
For example see the documentation and explanation that is available for the Schwarzbeck NSLK 8128, when it is equipped with the 'NSLK 8128 Opt. RC'.
