Rohde & Schwarz EZ-10 model 2
The Rohde & Schwarz EZ-10 model 2 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz EZ-10 model 2:
The frequency range of the Rohde & Schwarz EZ-10 model 2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz EZ-10 model 2.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz EZ-10 model 2 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz EZ-10 model 2
- Google image search: Rohde & Schwarz EZ-10 model 2
