Rohde & Schwarz NRP Channel B
Jump to: navigation, search
The Rohde & Schwarz NRP Channel B device driver is a Power Meter which is supported by RadiMation®.
Note: General information of this device driver can be found on the Rohde & Schwarz NRP page.
The following tabs are available in the advanced configuration of the Rohde & Schwarz NRP Channel B:
The frequency range of the Rohde & Schwarz NRP Channel B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz NRP Channel B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz NRP Channel B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
