Rohde & Schwarz SCIU
The Rohde & Schwarz SCIU device driver is a Amplifier, Switch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SCIU:
The frequency range of the Rohde & Schwarz SCIU as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz SCIU.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz SCIU is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz SCIU
- Google image search: Rohde & Schwarz SCIU
