Rohde & Schwarz SMA 100A
Jump to: navigation, search
The Rohde & Schwarz SMA 100A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz SMA 100A:
The frequency range of the Rohde & Schwarz SMA 100A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz SMA 100A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz SMA 100A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Documentation
The programmer manual can be found here
