Rohde & Schwarz Userport Controlled HM020
The Rohde & Schwarz Userport Controlled HM020 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz Userport Controlled HM020:
The frequency range of the Rohde & Schwarz Userport Controlled HM020 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz Userport Controlled HM020.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz Userport Controlled HM020 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rohde & Schwarz Userport Controlled HM020
- Google image search: Rohde & Schwarz Userport Controlled HM020
