Rohde & Schwarz ZNB 40
Jump to: navigation, search
The Rohde & Schwarz ZNB 40 device driver is a Signal GeneratorSpectrum AnalyserNetwork Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ZNB 40:
The frequency range of the Rohde & Schwarz ZNB 40 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ZNB 40.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ZNB 40 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
