Schaffner CBL 6112C
The Schaffner CBL 6112C device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner CBL 6112C:
The frequency range of the Schaffner CBL 6112C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner CBL 6112C.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner CBL 6112C is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schaffner CBL 6112C
- Google image search: Schaffner CBL 6112C
