Schaffner HLA 6121
Jump to: navigation, search
The Schaffner HLA 6121 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner HLA 6121:
The frequency range of the Schaffner HLA 6121 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner HLA 6121.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner HLA 6121 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
