Schaffner MN 2050D
The Schaffner MN 2050D device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner MN 2050D:
The frequency range of the Schaffner MN 2050D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner MN 2050D.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner MN 2050D is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schaffner MN 2050D
- Google image search: Schaffner MN 2050D
