Schaffner NNB 42
The Schaffner NNB 42 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner NNB 42:
The frequency range of the Schaffner NNB 42 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner NNB 42.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner NNB 42 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schaffner NNB 42
- Google image search: Schaffner NNB 42
