Schaffner UPA 6109
Jump to: navigation, search
The Schaffner UPA 6109 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner UPA 6109:
The frequency range of the Schaffner UPA 6109 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner UPA 6109.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner UPA 6109 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
