Schaffner VBA 6106
The Schaffner VBA 6106 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schaffner VBA 6106:
The frequency range of the Schaffner VBA 6106 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schaffner VBA 6106.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schaffner VBA 6106 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schaffner VBA 6106
- Google image search: Schaffner VBA 6106
