Schwarzbeck BBHA 9120A
The Schwarzbeck BBHA 9120A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120A:
The frequency range of the Schwarzbeck BBHA 9120A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBHA 9120A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck BBHA 9120A
- Google image search: Schwarzbeck BBHA 9120A
