Schwarzbeck BBHA 9120B
Jump to: navigation, search
The Schwarzbeck BBHA 9120B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120B:
The frequency range of the Schwarzbeck BBHA 9120B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBHA 9120B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
