Schwarzbeck BBHA 9120G
The Schwarzbeck BBHA 9120G device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBHA 9120G:
The frequency range of the Schwarzbeck BBHA 9120G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBHA 9120G.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBHA 9120G is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck BBHA 9120G
- Google image search: Schwarzbeck BBHA 9120G
