Schwarzbeck BBUK 9139
The Schwarzbeck BBUK 9139 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBUK 9139:
The frequency range of the Schwarzbeck BBUK 9139 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBUK 9139.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBUK 9139 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck BBUK 9139
- Google image search: Schwarzbeck BBUK 9139
