Schwarzbeck BBVK 9138
The Schwarzbeck BBVK 9138 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBVK 9138:
The frequency range of the Schwarzbeck BBVK 9138 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBVK 9138.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBVK 9138 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck BBVK 9138
- Google image search: Schwarzbeck BBVK 9138
