Schwarzbeck BBV 9718
The Schwarzbeck BBV 9718 device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck BBV 9718:
The frequency range of the Schwarzbeck BBV 9718 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck BBV 9718.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck BBV 9718 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck BBV 9718
- Google image search: Schwarzbeck BBV 9718
