Schwarzbeck CAT5 8158
The Schwarzbeck CAT5 8158 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CAT5 8158:
The frequency range of the Schwarzbeck CAT5 8158 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck CAT5 8158.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck CAT5 8158 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck CAT5 8158
- Google image search: Schwarzbeck CAT5 8158
