Schwarzbeck CDN AF5
The Schwarzbeck CDN AF5 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CDN AF5:
The frequency range of the Schwarzbeck CDN AF5 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck CDN AF5.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck CDN AF5 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck CDN AF5
- Google image search: Schwarzbeck CDN AF5
