Schwarzbeck CDN AF8
Jump to: navigation, search
The Schwarzbeck CDN AF8 device driver is a Injection DeviceLISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CDN AF8:
The frequency range of the Schwarzbeck CDN AF8 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck CDN AF8.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck CDN AF8 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
