Schwarzbeck CDN M3
Jump to: navigation, search
The Schwarzbeck CDN M3 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CDN M3:
The frequency range of the Schwarzbeck CDN M3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck CDN M3.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck CDN M3 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
