Schwarzbeck CVP 9222 B
The Schwarzbeck CVP 9222 B device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck CVP 9222 B:
The frequency range of the Schwarzbeck CVP 9222 B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck CVP 9222 B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck CVP 9222 B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck CVP 9222 B
- Google image search: Schwarzbeck CVP 9222 B
