Schwarzbeck ESLP 9145
Jump to: navigation, search
The Schwarzbeck ESLP 9145 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck ESLP 9145:
The frequency range of the Schwarzbeck ESLP 9145 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck ESLP 9145.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck ESLP 9145 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
