Schwarzbeck FT01 UKW
The Schwarzbeck FT01 UKW device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck FT01 UKW:
The frequency range of the Schwarzbeck FT01 UKW as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck FT01 UKW.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck FT01 UKW is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck FT01 UKW
- Google image search: Schwarzbeck FT01 UKW
