Schwarzbeck HFRAE 5160
Jump to: navigation, search
The Schwarzbeck HFRAE 5160 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck HFRAE 5160:
The frequency range of the Schwarzbeck HFRAE 5160 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck HFRAE 5160.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck HFRAE 5160 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
