Schwarzbeck ISN 8
The Schwarzbeck ISN 8 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck ISN 8:
The frequency range of the Schwarzbeck ISN 8 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck ISN 8.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck ISN 8 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck ISN 8
- Google image search: Schwarzbeck ISN 8
