Schwarzbeck NNBL 8226
The Schwarzbeck NNBL 8226 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNBL 8226:
The frequency range of the Schwarzbeck NNBL 8226 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NNBL 8226.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NNBL 8226 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck NNBL 8226
- Google image search: Schwarzbeck NNBL 8226
