Schwarzbeck NNBL 8226-HV
Jump to: navigation, search
The Schwarzbeck NNBL 8226-HV device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNBL 8226-HV:
The frequency range of the Schwarzbeck NNBL 8226-HV as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NNBL 8226-HV.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NNBL 8226-HV is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
