Schwarzbeck NNBL 8229-HV
The Schwarzbeck NNBL 8229-HV device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNBL 8229-HV:
The frequency range of the Schwarzbeck NNBL 8229-HV as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NNBL 8229-HV.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NNBL 8229-HV is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck NNBL 8229-HV
- Google image search: Schwarzbeck NNBL 8229-HV
