Schwarzbeck NNBM 8125
Jump to: navigation, search
The Schwarzbeck NNBM 8125 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNBM 8125:
The frequency range of the Schwarzbeck NNBM 8125 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NNBM 8125.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NNBM 8125 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
