Schwarzbeck NNLK 8121
Jump to: navigation, search
The Schwarzbeck NNLK 8121 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NNLK 8121:
The frequency range of the Schwarzbeck NNLK 8121 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NNLK 8121.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NNLK 8121 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
