Schwarzbeck NSLK 8127 option PLC
Jump to: navigation, search
The Schwarzbeck NSLK 8127 option PLC device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NSLK 8127 option PLC:
The frequency range of the Schwarzbeck NSLK 8127 option PLC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NSLK 8127 option PLC.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NSLK 8127 option PLC is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
