Schwarzbeck NTFM 8132
The Schwarzbeck NTFM 8132 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck NTFM 8132:
The frequency range of the Schwarzbeck NTFM 8132 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck NTFM 8132.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck NTFM 8132 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck NTFM 8132
- Google image search: Schwarzbeck NTFM 8132
