Schwarzbeck SBA 9113
The Schwarzbeck SBA 9113 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck SBA 9113:
The frequency range of the Schwarzbeck SBA 9113 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck SBA 9113.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck SBA 9113 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck SBA 9113
- Google image search: Schwarzbeck SBA 9113
