Schwarzbeck SGA 900
The Schwarzbeck SGA 900 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck SGA 900:
The frequency range of the Schwarzbeck SGA 900 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck SGA 900.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck SGA 900 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck SGA 900
- Google image search: Schwarzbeck SGA 900
