Schwarzbeck STLP 9128E
The Schwarzbeck STLP 9128E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck STLP 9128E:
The frequency range of the Schwarzbeck STLP 9128E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck STLP 9128E.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck STLP 9128E is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck STLP 9128E
- Google image search: Schwarzbeck STLP 9128E
