Schwarzbeck TEMZ 5231
The Schwarzbeck TEMZ 5231 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck TEMZ 5231:
The frequency range of the Schwarzbeck TEMZ 5231 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck TEMZ 5231.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck TEMZ 5231 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck TEMZ 5231
- Google image search: Schwarzbeck TEMZ 5231
