Schwarzbeck TK9420
Jump to: navigation, search
The Schwarzbeck TK9420 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck TK9420:
The frequency range of the Schwarzbeck TK9420 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck TK9420.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck TK9420 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
