Schwarzbeck VHAP
The Schwarzbeck VHAP device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VHAP:
The frequency range of the Schwarzbeck VHAP as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck VHAP.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck VHAP is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck VHAP
- Google image search: Schwarzbeck VHAP
