Schwarzbeck VHBA 9124
The Schwarzbeck VHBA 9124 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VHBA 9124:
The frequency range of the Schwarzbeck VHBA 9124 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck VHBA 9124.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck VHBA 9124 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck VHBA 9124
- Google image search: Schwarzbeck VHBA 9124
