Schwarzbeck VHBD 9134
The Schwarzbeck VHBD 9134 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VHBD 9134:
The frequency range of the Schwarzbeck VHBD 9134 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck VHBD 9134.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck VHBD 9134 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck VHBD 9134
- Google image search: Schwarzbeck VHBD 9134
